Computers & Internet Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need XP drivers for a Belkin 4-Port DB25 Switchbox, model f1b028-e
Anonymous
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Nov 22, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
58
Questions
0
Helped
11444
Points
177
Err, its just a passive switch so there are no drivers needed. It just passes the signal through it to the printer
How to connect to the computer?
Devices: Canon CanoScan FB330P/FB630P Color Flatbed Scanners
Check pages 22-23 of this copy of your Canon Canoscan 630P Product Guide.
You'll need an "IBM-type" parallel printer cable - with a DB25 on each end, and your computer will also need to have an "IBM-type" DB-25 parallel printer port.
What the Canon Product Guide fails to mention is that this "IBM-type" printer cable is a kluged Centronics parallel printer cable, but became so popular (on older computers - your laptop may not have this port), that it got an IEEE standard: IEEE 1284 (with DB25 connectors on both ends).
You'll need a DB25-to-DB25 M/F cable, meaning DB25 connectors on both ends, with a Male on one end, and a Female on the other end.
The Male DB25 will plug into the Female DB25 connector on your computer/laptop, with the Female DB25 going to the FB630P Color scanner..
Here are some pictures/pricing:
http://www.computercablestore.com/IEEE_1284_Printer_DB25_to_DB25_catID2134.aspx
The nice thing about the design of the Canon FB630P Color Scanner is that the scanner also has a Female DB25 Printer port for an existing parallel printer, so when you connect an FB330P/FB630P to your system, your existing parallel printer is daisy-chained through this port - so you needn't give up you printer (to scan), nor must you install another parallel printer port onto your PCI-bus tower PC to keep your printer.
Canon Canoscan FB330P/FB630P Color Scanner Product Guide (82 pages):
http://canoncanada.custhelp.com/ci/fattach/get/267/
Most modern printers are USB-attached to laptop systems, so you may need an adapter, an example of which is seen here:
http://www.cablestogo.com/product.asp?cat_id=116&sku=16899
2answers
F5U301 - are there drivers for windows 7
It looks like it is an older product and only has a driver designed for Windows XP SP2.
2answers
G'day, I have a Cisco 1841 router which I would like to get the cable or pinouts to connect a PSTN modem. The aux port is RJ45 and the modem db25
Here is the pin out:
RJ45 DB25
1 -------- 4
2 -------- 20
3 -------- 2
4 -------- 7
5 -------- 7
6 -------- 3
7 -------- 6
8 -------- 5
My adapter DB9 FEMALE TO DB25 FEMALE doesnt allow me to see my Printer
Are you tring to run a parallel printer from a serial port? If so then it will not work at all. You would need a serial to prallel adaptor that also has the software drivers needed to convert the signal.
Need a motherboard with DB25 male RS232 serial port
to get ur motherboard just go to the website of that ,,u can find it bt surfing
BELKIN G Plus Mimo USB Adapter
u dont need to change any thing on the pc make sure u r using the updated version of driver and still its not working then u need to replace the USB adapter
thx
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
