1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
and
1. Click on the start menu
2. Go in to Control Panel
3. Click on Printers and Faxes
4. Right click on your printer (Canon IP1600)
5. Go down to properties
6. Then click on maintenance
Step 2 - Click on ‘View Printer Status…..’
Step 3 - Click on Option
Finally, click on enable status monitor. This will turn off the monitor and allow you to use
refilled ink cartridges.
If at any time you get the ‘Ink out’ message on your PC a light under your power button on the
printer will flash. To continue printing, simply press the button and click the close button on the
warning (marked X).
You may need to do this a few times also run the printhead alginment page after.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
