20 Most Recent
Canon PIXMA MP540 All-In-One InkJet Printer Questions & Answers
How do i reset canon mp540 printer?/disable ink
These are instructions for the Pixma mp560 printer, I couldn't find the mp540 printer on the canonusa.com website.
I do not know how to disable ink monitoring levels.
Default Settings
Instructions to change the machine back to its default settings.
- Press the <HOME> button.
- Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the <OK> button.
- Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the <OK> button.
- Use the Easy-Scroll Wheel or the up / down arrow to select [Reset settings], then press the <OK> button.
- Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press <OK>.
- Press the <HOME> button to return to the HOME menu.
Note: Changes the settings back to the default (factory settings), except for the language for LCD messages and the position of the print head.
How do I fix my
B200 error means
"Print head Temperature exceeded". In your to solve your problem you need to perform a printer reset. Click Here to view the Canon reset guide or you can follow the steps below:
1) Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press the power button for 1 sec.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again.
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Canon Printer Pixma MP540 with
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Why won't my printer print?
I'd tried cleaning/deep cleaning a billion times and it was never getting any better, and my ink levels were just being depleted from the process. STRESSFUL. But actually after calling in, I was asked to check whether there was a slit above the ink label (like an upside down L) on the large black cartridge, and I had to remove a bit of a packaging sticker to see if it was there. It was this sticker remnant that was actually blocking the slit and stopping cartridge from being used properly. I don't know how this works exactly but that's how it went down. After removing the sticker, it printed black like a charm.
SO, if you've tried cleaning more than should be necessary and it's not a problem with the print head, it might just be a bit of sticker that is causing your problem. Thought I'd share, just in case.
Mijn Canon MP540 geeft in
not the printhead
clean the ink absorbers located at the right side
bottom remove them and put them in can with water
also the transparant flaps in front of the absorbers
How do I clear a B200 error. I have turned printer of but error is still there
B200 error on a Canon Printer generally means a permanent failure of the print head caused by overheating (running out of ink and ignoring the message and printing further).
A costly mistake.
In the future, do not print after the first message to change an ink tank. Simply replace it as new heads are very pricey.
But a new head is still cheaper than a new printer, so if the rest of the printer/Scanner still works well (or I should say that it did before the B200 error, as that is a "show stopper!", and the printer will not operate further once this error is detected. Only a new head will restore the printer to working), buy a new head.
Sometimes the head is damaged, but no fault error is generated and the printer simply prints nothing on the paper, (or missing one colour or some Pixels and cleaning does not help), but thinks it is. I am sure that this is just that the fault detection is simply not sophisticated enough to detect some errors.
For example, it can detect a shorted head element, but not an open circuit problem for example!! Just guessing though!!
Canon keeps the actual reason for many errors secret, I personally do not know why.....this is one of those errors.....
By the way, second hand heads on ebay are generally a waste of time unless you can go there and test the head before buying, which is very unlikely.....Only buy Brand new Canon heads, with a guarantee and still sealed in the original bag, check at purchase time....from a reputable dealer.anon printers showing this error with
I have fixed several Canon printers with a new head. MG5xxx for example, but I cannot guarantee the fix for simply any printer, its only my limited experience that has been tested....
Best of luck.
Printer displays error U052 saying: The type of
Error U063 appears when the printer detected that the ink cartridge was refilled or the ink level reach its limit.
To remove this error you need to reset your printer. Follow this procedure
1. Disconnect the printers power outlet.
2. Press and hold the STOP/RESET button (red circle with a triangle) while connecting the power outlet back.
3. While holding the STOP/RESET button, press and hold the POWER button
4. Release the STOP/RESET button while still holding the POWER button
5. While still holding the POWER button, press the STOP/RESET button twice
6. Release the power button
7. When the indicator light COPY Green - press STOP / RESET button 4 times
8. Restart your printer.
Let me know how it goes.
Canon iP4700 with error 6C10
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
http://www.fixya.com/support/t5998845-error_code_6c10_meanHope this helps.
MP640 showing a 6C10 error
- First do printer off
- Press and hold resume Button & click Power button. By doing this green led should be on
- While holding the Power button,release the Resume Button
- Without releasing the Power Button, click Resume button for 2 times and then release both Buttons.
- Now Click Resume for 4 times then soon click Power button,to confirm the selected action reset counter absorber
- At the end turn off the printer and turn on again
