2001 Nissan Sentra Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 sentra no communication with scan tool
I have a 2001 nissan sentra and i can't get my scan tool to communicate with the ecu. the engine light is on
Steven Wingert
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Feb 11, 2010
Steven Wingert
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
56834
Points
148
Take a few minutes to make sure you dont have a blown fuse....Run through them with your test light...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2102
Points
2001 nissan sentra gxe ecu not communicating, tried the fuse, fuse keeps blowing.
1996 Nissan Sentra E. No power to OBDII port or radio after repairs.
USA only answers, I do not do non USA OBD2, ever.
the OBD2 port has a power pin 12vdc, and the fuse is blown
we replace the fuse
the hand tool has battery do not be fooled by said batttery.
the ODB2 port 16 pins total, and pin #16is power 12vdc,
some old (all) scan tools do not work on newer cars at all.
the secret here is missing pins on scan tool (wow).
1996 tools being the worst (have some too, have many tools)
The radio fuse is bad. (we always check fuses first)
no power no joy and no free energy,
the true wiring diagram is called a factory service manual.
can also be seen at mitchells DIY
$20 and its all there to read, vast info.
https://eautorepair.net/Marketing/Default.asp
this is not spam it is FACTs (best data lowest cost)
I have a 1992 Toyota RV. It quit on freeway, has no spark or injection plus has no check engine light. Tried 2 ECU rebuilt reprogrammed. Please help, need to talk to someone to explain all tests. Bob
Hi Bob
You need a mobile mechanic with a $5,000 professional grade scan tool computer to diagnose the electronics. I suspect your replacement ECU are faulty and the communications or power to it. Look at the Scotty Kilmer YouTube channel and search scan tool. He uses them frequently and shows what they are capable of. He did a Nissan Altima within the last couple of days.
What could be a problem with Nissan Sentra 1997 not communicating with a scan tool
The service and repair manual with diagram will help you to locate and fix the problem and you will get the manual from the given link https://toolsnyou.com
1helpful
2answers
Does nissan sunny fb15 have a computer box?
Hi there I am Brandon I am a mechanical n electrical engineering technical technician and 4 generation mechanic I am the man that regular mechanics call when they cant find out the problem the pro... don't have any thing do with the ecu you have a throttle plate sticking and it is been left open that is making it act up
thank you n God bless
1990 nissan sentra loses power and dies at stop signs
My friend's 2001 Hyundai sonata does this. I found out many issues with the car, most of the issues were censors. It was the main issue in the Hyundai... Try scanning the ecu for codes, it will tell you something.
Transmission
a truly horrible gearbox,seems the gearbox ecu has failed
1helpful
Nissan 2001 exalta ecu location
Also called Sentra... Engine computer is located under the dash by the firewall. This is where the ecu is located on '01...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Do you need any special instruction to install the ECU, sentra 20
i do not know but give these websites a try www.autozone.com and www.alldatadiy.com if all fails stop by your local Nissan dealership in the parts department and they be able to print you off the pictures and diagram you will need wish you the best of luck Michigan Man.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
