For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming
signal first and then have their composite video output (A/V) connected to the
DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here:
http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
No. I'm having problem with three different inputs--PC, HDMI, and Component 1 and 2. The coaxial cable antenna input works fine.
Is this when you are trying to use the cable TV input?
