20 Most Recent Samsung HP-T4254 42 in. Plasma Television Questions & Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Samsung HP-T4254... | Answered on Jun 21, 2017
If you need the code list for the original HP-T4254 remote, BN59-00599A, these are listed in the manual starting at page 22. The steps to program the remote are on the preceding page. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-TYaga4aDv9F/p_305HPT4254/Samsung-HP-T4254.html . The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20071022131600/Manuals/305/305HPT4254.PDF .
Please note that the codes programmed into the remote will probably not operate devices that are newer than the TV. Sometimes electronic devices that were released less than 6 months before the remote was programmed will not respond to the available codes in the given remote.
If you are trying to find a Samsung TV code that will work with another remote, please indicate which universal remote you are trying to program. (There is a Redi-Remote replacement for the BN59-00599A that does not function as a universal remote.)
I hope this helps.
Samsung HP-T4254... | Answered on Sep 18, 2016
There are two possibilties, the buttons on your TV are stuck on one position or your control inteface board is damaged. I would need mopre info to rectify.
Samsung HP-T4254... | Answered on Aug 25, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.....
Samsung HP-T4254... | Answered on Aug 21, 2016
If relays are clicking, the problem could also be the diode connected to the relay or its own power supply. Check whether the relay is getting power enough to remain activated. This chattering can also be caused due to relays becoming weak or by short circuits on its load.
Samsung HP-T4254... | Answered on Dec 13, 2015
the clicking is the relay sending power to unit/but if there is a fault it will power down/tv shop mate
Samsung HP-T4254... | Answered on Nov 15, 2015
If your looking at channels in the high numbers on cable, make sure that you are not going through a cable surger protector with the cable. They cause a problem on the high cable channels.
Samsung HP-T4254... | Answered on Sep 05, 2014
Hi Rickpo:
After installing the $11 kit and the additional $13 kit recommended by (http://preher-tv.blogspot.com/2010/01/samsung-hpt4254-no-power-repaired.html) mostly surface mount diodes (also available on Ebay), the Samsung HP-T4254 came back on, but would only play for 4 minutes. I found DX801 flowing both directions, replaced it with a diode from Fry's. Works great, $26 total repair costs :-)
Samsung HP-T4254... | Answered on Aug 15, 2014
Unscrew it from the back.
Samsung HP-T4254... | Answered on Mar 19, 2014
To know more about this, you have to download its repair manual. Its disassemble section, will give you all details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Samsung HP-T4254... | Answered on Mar 16, 2014
I have the same problem, many people say none works, I have tried funai, phillips, etc. They say "ON" made this model but their website gives no answers - Still looking for a answer! Anyone?
Samsung HP-T4254... | Answered on Jan 08, 2014
0291,0290,0299 are the codes to check. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view.It will make search easy
Samsung HP-T4254... | Answered on Jan 03, 2014
Samsung HP-T4254 42 in. Plasma Television Logo
205 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung remote hp t4254 need code please
  • Televison & Video
