Acer Aspire 5500 5570-2609 Laptop Logo
Posted on Jan 07, 2008
Acer Aspire 5315 with Windows Vista Home Basic will not connect wirelessly to our router but will connect to others.
Our Acer Aspire laptop was connected wirelessly to our Belkin router but suddenly disconnected and will not reconnect. The desk top computer is windows XP and our broadband provider is Virgin broadband. It will connect to other routers but not ours. Does anyone know why?
  • 2 more comments
  • Anonymous Mar 08, 2008
    How do I set up my acer 5315 to print from my belkins router. Basically I just dont know how to activate the laptop to print wireless ...Please help
    asdfa
  • Libbis Jun 09, 2008
    For the first 3 weeks I was connnected to our Optus Broadband wirelees modem, and then when the kids accidently turned of the wireless button on the laptop but now that I have turned it back on it still can't find our wireless modem even though I re entered the wep key, it can't connect? Please advise. Many thanks, Marlene
  • Anonymous Mar 25, 2014
    There seems to be an internet connection issue. It drops the connection all the time and has to be restarted to reconnect and it takes an extended period of time and doesn't reconnect all the time. What can be done to fix this?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
915
Points
Hi i have just bought a Acer Aspire 5315 on vista i wanted to put it back to factory reset but it seems that they have taken out the back up to do this can i get a disc from any were or any help i would be most greatful thanks dee
A
Anonymous
The issues might also be related to the level of encryption.
Can you connect if you setup your wireless AP as Open with no encryption? Apparently Viasta has issues with WEP 64bit keys.
Configure your AP with WPA-PSK authentication and then chose between TKIP or AES, which ever works for you. Seems TKIP works for some while AES works for others.
A
Anonymous
Anonymous
Level 1:
Scholar:
  • Contributor 32 Answers
  • Posted on Jan 08, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
32
Questions
Helped
15036
Points
95
There are two things you can do to attempt clearing this issue up.
1) go into the wireless networks tab in the properties of your wireless card. this section stores information on all of your preferred networks and the encryption keys. Remove all the networks from this list, reboot, then try connecting, it should ask you for your password then connect fine. This happens occasionally when windows takes too much control over the Zero Config service.
2) Reset your router with the pin on back after removing any mac filtering, changing your wep key (try using WPA for more security) and making sure all your stuff is set to auto. after resetting try step 1 and retry.
If this does not work, there may be an association issue between the hardware, try using a LiveCD linux that can use your wireless card to see if it can connect. If it can, it is simply just windows.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 28 Answers
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
28
Questions
0
Helped
11804
Points
32
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Wirless setup
try these drivers
http://laptop-problem.blogspot.in/2012/01/acer-aspire-5315-windows-xp-driver.html
I have the acer5715/5315 series abd it crashed. I had it fixed and the guy put windows 7 so now none of my acer programs work. How can I get these to work with windows 7
Operating System Windows XP Professional with Service Pack 2
Windows XP Home with Service Pack 2
Windows Vista Home Premium
Windows Vista Starter
1. Before upgrading to windows 7, you must check the specification of your acer aspire 5315.
2. Windows 7 is better than windows vista but if you are really wanted those acer programs to work. You have to downgrade your operating system from your previous operating system.
2answers
Compatibility printer/laptop
If both are fairly new then yes they should be.
That laptop comes with vista home basic and the printers website has drivers for xp and Vista, even 64 bit vista. So you should be good to go.
Reinstalled vista home basic on acer aspire 5520 wireless
Do you have a disk or the wireless router? If this hasn't been re-installed then the notebook will have no way of connecting to the net.
1helpful
Acer 5315 lost driver and hardware
The drivers you need are here
ftp://ftp.work.acer-euro.com/notebook/aspire_5315/vista/
Wireless connection problem
hello.i have a problem with my laptop (acer ASPIRE 5315).when i install XP sp2 i get a problem with my wireless connection where i cant connect via its wireless!!!it asks me to install broadcom 802.11g.it happens just with windows xp but doesn't happen with Vista system.I need your help please
Vista home basic to vista home permium didnt work
you might need to upgrade you hardware in your computer so that you computer can handle vista you have to have atleast one gb of ram for it to even try to boot up
New acer 5315
Make sure that the wireless radio/switch is enabled on your laptop if its has built in wireless and normally if your wireless router has security enabled you need to create a profile or initiate the connection. For Windows Vista go to Control Panel and Look for Network and Internet then go to Network and Sharing Center, on the upper left hand side of the window look for a task that says Manage Wireless Connection then click Add then choose "Add a network that is in range of this computer" and check if it will display na name(SSID) of your wireless router, if it does just highlight the name and click connect(if the router has encryption you may need to verify or get hold of the wireless security(WEP or WPA) key that is configured on your router. It will be most helpful if you could provide some imformation about you laptop like the windows version(XP or Vista) and the brand name of your wieless router.
I have an Acer Aspire 5315 Series laptop, and have been having some problems with the wireless modem adapter that is installed into the computer. I recently did a change of the OS system, from Vista, to XP...
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=2246261&CFTOKEN=17581077
Above is the link where you can download all the drivers for your Aspire 5315 series laptop. It is directley from the Acer support site and it is free. You do not have to buy the CDROM.
I hope you find this helpful. If you do please don't forget to rate me FixYa.
If you ever need other technical support feel free to contact me. Always free as for all the times others have helped me for free.
Thanks
George
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
