1. Remove the rubber hood gasket at the base of the windshield along the car-right side by pulling up on it
2. Pull up and remove the triangular plastic shield in the car-right rear corner of the engine compartment
3. Remove the rear bolt on the large diagonal bar holding the fuse box
4. remove the two front bolts on that diagonal bar, and the
other nearby car-right bolt holding the front of the plastic
shield to the front rail
5. Pull up and right on the large bar and fuse box to position it out of the way to expose the battery
6. remove the bolt and spacer at the rear lower base of the battery
7. first remove the negative battery cable (8mm), then the positive cable
8. pull the battery out
9. swap the thermal cover onto the new battery, remove
protective terminal caps (if there), and reverse the procedure to
reinstall the new battery. Always install the positive cable before the
negative to avoid welding your wrench to the car.
You mean the accumulator? Assuming you know where it is:
1. Turn off all consumers. Remove the wires, - first, then the +.
2. Look for any fixators, usually a small bracket at the bottom, and loosen or remove them.
3. Place a new accumulator according to vehicle manual or with same dimensions and same or more Ah (BUT not less Ah, more Ah will cost you more but will give you more "starting tries", less Ah will cost you less but assuming you replace the original battery, won't work).
4. Fasten the fixators from 2.
5. Connect the wires, first +, then -.
Users, please rate your solutions.
You need to remove the three bolts securing the bar that the fuse box is clipped to, then slide the tube out and move the fuse box out of the way. Then use an 8mm socket to remove the battery cables. You may need to loosen 2 more screws that hold a piece of plastic against the battery toward the bottom of the cavity. This piece of plastic holds the battery in place.
