Hi, my Sharp XR-10X bulb was blown and was changed. Now on attempting to power up the projector, the power LED comes on steady (green) and the lamp LED flashes (green). after a few seconds both LEDs are on steady (amber). There are no other lights on the projector
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
The light bulb must be seated in perfectly, otherwise it won't see a connection and won't come on. take the bulb out, and make sure the connections don't have any dirt on it. Anything that can obstruct a connection. Give that a try.
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
