Kodak EasyShare M1073 IS Digital Camera Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How often should the camera be charged
I charged the camera yesterday and today,when i switched it on,it switches off after 30 sec.
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Oct 12, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184348
Points
12747
This is not a straight forward question, it would depend on how often you wisg to use it. It also depends on the type of batteries you have installed. Nic Cad, Polymer, NMH. Polymer don't need charging often because they have good holding power for months. The cadmium and NMH types need a regular charge, for instance at least a top up onjce a month to keep them live. If you dont use the camera much remove the batteries whjen in storage place them in a kliplock bag and place in freezer. This may be extremem but keeps the batteries alive for years.
Always before use fully charge the ewith an intelligent charger, one that stops when capacity is reached. This prevents damage from Overcharging.
hope this is helpful,
Please rate the help[++++Thanks for using FIXYA
How do I fix error 32 message on canon a3100?
Error 32 is a shutter related problem Try this :- Switch off the Camera, wait 10 secs, Open the battery door and remove the battery, wait 30 secs insert the battery and close the door. Wait 10 secs switch on.
1helpful
MY GARMIN STREETPILOT C310 WORKED THIS MORNING, BUT NOW WILL NOT SWITCH ON?
It is also 7+ years old. in technology years that is like 140 years old. retire it and get a Nuvi.
Remember that time you went to start your car and it worked yesterday but today it would not start... bad stuff happens.
If you are holding out hope, try leaving it plugged into the car or outlet
try holding the power button for a long time (30 sec)
try plugging it into a computer and see if anything happens.
Mar 22, 2015 • Garmin GPS
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
I got my camera 3 weeks ago. Now Im on vacation in Thailand and used the camera snorkeling. Yesterday the camera "froze" so the only way to get it going again was to remove the battery. Today...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Got a new 16gb spy camera yesterday. Charged the equipment for 3 hours but not able to use it for more than 10 secs immediatly after charging. It automatically switches off, after which there is no...
Try lithium batteries in it to see if that works better.
They have 1.5 Volts in them.
How much voltage do you charged batteries have?
Jul 29, 2010 • Cameras
The device switches off after a very short time. As this happened previously, I asked Currys, but they didn't know the answer - just reset the receiver and told me to charge it up. I did this before using...
Go too preferences and click then click the arrow until you come to battery saving, click that as it may turn of your screen after a few seconds during your route
2answers
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
3answers
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
1helpful
IPod Nano new version 8gb, charges yesterday will not switch on today
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
good luck
please mark the post with a fixya
Cannot switch on
check whether the switches are jamed or not? did u try with the charger alone? there is no way u can get tape with out powering it up.
ny way u hav i-link cable of that one?|
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
