20 Most Recent Kodak EasyShare M1073 IS Digital Camera Questions & Answers
Use the flash when you take pictures at night, indoors, or outdoors in heavy shadows. You can chose what flash mode, by pressing several times on the little button on top of the camera where the lightening logo is. One of the settings is flash off. Make sure it is not in that mode, because even when it is dark the flash won't fire. The other modes are flash, fill in flash and red eye reduction flash.
Kodak EasyShare... | Answered on Jan 20, 2014
What do yu mean with where are the batteries?
Your camera only has one battery. It is in the same compartment where the memory card goes in. The battery is the small square package with only three golden contacts on it. If you did not insert a SD card (was not included with the camera) you only can shoot a few pictures and then it says memory full.
Your camera accepts SD and SCHC card, if you still want to buy a memory card.
Yes, but you will need to purchase a "Rescue" program such as Rescue - Pro, this enables you to search a camera memory card, and retrieve the last images taken.  Beware however that if your son has taken more photos after the ones he deleted then the "Rescue" software may have trouble.
The best option is to withdraw the camera card from use until you have used the "Rescue" software, to prevent corruption to the image files. These programs are available for down load off the web, at very reasonable prices, or maybe available when purchased with a high end memory card, such as San Disk Extreme IV Series Cards.
Hope this helps Ian
Kodak EasyShare... | Answered on Nov 20, 2013
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
Kodak EasyShare... | Answered on Jun 24, 2012
Here's the appropriate page in the extended user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00864/urg00864c4s3.shtml
Kodak EasyShare... | Answered on Aug 16, 2011
If the camera has recently been dropped it may have lens damage that is preventing the camera from powering up/down. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Kodak EasyShare... | Answered on Feb 24, 2011
In any still mode, press the cursor-down button (marked with a one-handed clock) to cycle through the available self-timer modes. Start the self-timer by pressing the shutter release button.
Full details are in the extended user guide in the "Using the self-timer" subsection of the "Doing more with your camera" section.
Kodak EasyShare... | Answered on Feb 05, 2011
Remove the battery, then reinsert correctly
Install new battery.
Charge rechargeable Camera does not battery
Kodak EasyShare... | Answered on Jan 06, 2011
It's important to set the date and time so that pictures and videos are organized by the date taken. The date and time procedure varies slightly between camera models, but generally:
  1. Turn on the camera.
  2. Press the Menu button.
    If you see a Setup tab, press the Right arrow button to highlight the Setup tab. If you don't see a Setup tab, press the Down arrow button to select Setup, then press the OK button.
  3. Press the Down arrow button to choose Date and Time (or similar), then press the OK button.
  4. Press the Right/Left arrow buttons to move between year, month, and date. Press (or press and hold) the Up/Down arrow buttons to scroll through the year, month, and date.
    Use the same procedure to set the time.
  5. When finished, press the OK button.
NOTE: If your KODAK Camera has a touchscreen, the same principles apply. Tap the Menu icon, Setup, then Date and Time (or similar).
Kodak EasyShare... | Answered on Nov 03, 2010
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Kodak EasyShare... | Answered on Sep 03, 2010
OMG this just happened to mine on 6/17...someone told me to try buying anew battery., that even though its a rechargable battery they still can die.!!!!
Kodak EasyShare... | Answered on Aug 23, 2010
You can use any of five different methods.
http://www.kodak.com/global/en/service/publications/urg00865toc.jhtml?pq-path=13000/13001
Kodak EasyShare... | Answered on Aug 01, 2010
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Kodak EasyShare... | Answered on Jul 07, 2010
Time to start using a card reader.
Kodak EasyShare... | Answered on May 10, 2010
Tip
Kodak EasyShare M1073 IS digital camera Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Kodak's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
on Mar 08, 2010 | Kodak EasyShare M1073 IS Digital...
Sorry it is not possible
Kodak EasyShare... | Answered on Jan 18, 2010
OoW. repair 48,44 pounds + postage.
If KODAK cannot fix the camera you will be offered a replacement for the same price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Kodak EasyShare... | Answered on Dec 02, 2009
This problem is frequently due to either weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Kodak EasyShare... | Answered on Nov 26, 2009
Kodak EasyShare M1073 IS Digital Camera Logo
42 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
batteries
  • Cameras
