I had a similar problem with the C:32:21.. but when I took the tape and put it back in as suggested with someone else.. a new problem came up. Now my camcorder won't play the tape. It's it's not recognizing that my tape is not a blank tape. I can hear it fast forward, rewind, and play, but no picture shows up. :**( Please help!
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head. good luck! Luwangula
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
had a similar problem a while ago, took the camcorder to repair. the problem was that the reading-head (the part that is incharge of reading the tapes) needed cleaning. i used a cleaning cassette - problem solved.
