20 Most Recent
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Questions & Answers
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Cassette won't eject
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
- Turn off the camcorder.
- Remove the battery from the camera.
- Remove the AC power supply from the camera.
- Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
- Slide the power switch back to the OFF position.
- Connect the AC power supply to the camera.
- Attempt to open the cassette compartment.
How do I reset a sony handycam to factory specs
Plug off it from mains. Take out the battery and take out also the battery cell inside the screen place (when opened) . Ligth on your camera for ten seconds. Switch it off and replace the elements. It's done!
I need driver for this camerato install in my
If you already have a 1394 connector on your motherboard, you dont need any driver. Just launch a grab software for DV and it's up !
Free software:
http://paul.glagla.free.fr/captureflux.htm
My camera displays everything in green.
I have the same problem with my DCR-VX2100 and according to another website that I found, the camera has a defective CCD, a known problem that was covered under a recall program from Sony that may or may not have expired.
If it is out of warranty, Sony charges a flat rate to fix and return ship the camera to you. Go to:
https://eservice.sony.com/webrma/web/index.do and enter your camera's model number (DCRVX2100), your purchase date and zip code. My quote was $516, which is reasonable, but I'm going to check several local shops as well to see if they can fix this known problem for less. Good luck.
