Default password I recently acquired a used Troy 2933A print server, which I have been able to reset, but need the default password to be able to login as admin. Thanks
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users> Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
From the main BRAdmin screen double click the appropriate printer.
Enter the print server password (The default password is "access").
Click the Control tab
Click the Restore Factory Defaults button
Click the OK button when you have read the warning message.
The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
From the main BRAdmin screen double click the appropriate machine.
Click Network Configuration tab, Control Panel and select Set Default.
Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
Connect to the printer using a web browser.
Click Network Configuration.
Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
Press the Menu or Menu/Set key on the control panel.
Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
Select Reset.
Select Yes.
The machine will re-start, re-connect cables once this is complete.
put the special reset button at the back for a few second with a pin.
When reboot ready, Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default). Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In
Then change settings and passwords.
Via a web browser
reset the print server by using the BRAdmin application. To reset the print server (excluding TCP/IP parameters) follow these steps:
Select Reset.
Select Yes.
The machine will re-start, re-connect cables once this is complete. please rate it
The D-Link DP-301U Print Server does *not* have a password by default. If you have come into the possession of one and it is password protected, then it is likely that the previous owner added a password.
In order to bypass it and reset the Print Server, while the device is powered on, you will have to hold down the RESET button on the back using a paper clip for 10 seconds.
[NOTE: If this helps, please leave feedback.]
The Linksys default login = admin and the default PW = admin.
If you have forgotten the changed password the you can reset the Linksys back to the factory default by power up the Linksys and pressing the pinhole RESET button at the back of the Linksys for 30 secs. Then enter the configuration URL and configure the Linksys with a new password plus the wireless SSID and encryption etc.
The password is extendnet. See link below
http://www.support.xerox.com/SRVS/CGI-BI...
Habe das gleiche Problem.
Wie ist das Password ????????????????
