The problem started on super load, then large, and now is starting to happen on medium load as well. Water will fill to a level and stops the cycle. This would happen prior to the wash cycle or prior to a rinse cycle.
Pushing Start would reset to the beginning of the cycle.
Whether it is related or not, the fill time seems to be quite long.
SOURCE: maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
SOURCE: Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
SOURCE: Maytag top loading washer fills up but won't stop
Check the fill control device and the tube that goes to it. Make sure there is not any debris in the outer tub where the tube connects. You may be able to push the drum aside to check.
SOURCE: Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
SOURCE: older maytag wahser water level and agitate cycle
you need to replace the water level switch
