20 Most Recent Maytag Centennial MTW5800TW Top Load Washer Questions & Answers
After pushing start, lid locking light flashes, clicks like it is locking but is not locked and nothing happens but it keeps clicking
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
12/4/2017 2:43:36 AM • Maytag... • Answered on Dec 04, 2017
Model# MTW5870TW0 se#CU0440362
this is a design 2000 mfg by whirlpool. great design and been around for some while. "If" it drains but doesn't spin or agitate, it is the transmission drive coupler. part no 285753a. very common problem. it is the sacrificial part between the transmission and motor. Amazon com 285753A FACTORY OEM GENUINE WHIRLPOOL KENMORE DIRECT DRIVE... 61ipflinsil._sl1000_-edhu4choobgnyzitajc4r1ab-4-1.jpg
6/13/2017 4:15:25 PM • Maytag... • Answered on Jun 13, 2017
Lid won,t unlock
press cancel twice and unplug. If that doesn't work then the lock maybe faulty.
4/3/2016 9:31:03 AM • Maytag... • Answered on Apr 03, 2016
Spin cycle not working properly. A little water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
3/24/2015 2:03:17 PM • Maytag... • Answered on Mar 24, 2015
Will not staya locked so water wont come in
inter lock
2/14/2015 11:31:07 PM • Maytag... • Answered on Feb 14, 2015
3answers
How do I get my clothes to SMELL like clean clothes? Darn washing machine stinks them up!
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
2/4/2015 9:02:26 PM • Maytag... • Answered on Feb 04, 2015
Washer will not drain and go to done maytag centennial washer cloths still to wet to put in dryer
its clogged empty your pockets before washing
9/4/2014 2:07:09 AM • Maytag... • Answered on Sep 04, 2014
0answers
Lock sensor keeps turning off. Machine won't run
Sensors are usually engaged by a depression of a tab.located directly under the cover. Replace the tab in the cabinet or use something to ensure it is pressed down.
6/15/2014 2:23:21 AM • Maytag... • Answered on Jun 15, 2014
Maytag Centennial MTW5800TW Top Load Washer Logo
198 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
begins fill wash stops starts low
  • Washing Machines
