20 Most Recent
Maytag MHWE200XW Washer Questions & Answers
Maytag 2000 series shows error code f6 e1. How can I fix?
Before spending much time and possible unnecessary work, the E1-F6 code may be nothing more than your bottom cover plate is not in place or missing. Recently was servicing a Maytag 2000 series wash and during the inspecting of the cycles it quit and flashed those codes. I had been testing it WITHOUT the bottom cover plate on. When I went to install it back on the code disappeared. Problem simply solved.
How to clean the drin filter
If there is enough room put a large adjustable or water pump pliers on the cover,i used the adjustable and put a screwdriver through the hole in the end and very gently applied pressure until in moved, I sprayed a little lube in the space between the cover and housing and it came off much easier then. There was so much debris in the trap and it stinks really bad, a large dish is needed under the cover as a lot of water will come out. Clean out the trap and reassemble using vaseline or grease to help the o ring seal.
Water leaking out of front of washer
At a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
