SOURCE: Error code print unable 5A
On most printers that are manufactured today have an error chip built onto the motherboard of the printer. If your printer experiences an error. It will register it on on the chip. You will continue getting the error because it needs to be cancelled. To cancel this error follow the instructions below:
1) Turn print on
2) Unplug the printer from the power
3) Wait at least 70 seconds
4) Plug it back in
The error should be cancelled
From Brother's website:
Print Unable ##:
Turn off the printer. Wait a few seconds, then turn it on again. If this does not clear the
problem, call your dealer or a Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
