SOURCE: Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
SOURCE: enter passcode screen is on, unable to enter code, appears frozen
you can fix it by restoring it in iTunes.
Here is a way to put it in recovery mode.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Iphone
and itouch dfu mode
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
SOURCE: Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside
Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
SOURCE: 2001 Audi A4 radio in safe mode. Battery was
sorry to say, you will need to take it in, it needs to be hooked up to their computer to reset and have it start up poperly. It just like a pc when it crash it will try to start in safe mode until you select "Normal" start up
