20 Most Recent
Sharp AR-275 Copier Questions & Answers
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
Have error code e7-80 on
Usually E7 errors have to do with the scanner or the optics. You should get a hold of a technician to see what can be done to fix it.
ERROR L4-01
What you have is a main motor lock. Check to see if you have anything blocking the movement of the drum, it could be anything from a staple, a jammed sheet of paper, or a broken drum separation pawl. If you have already removed something from the drum area do a SIMM 14-01 to clear the code.
There also could be trouble with the main motor itself. Check the motor by using SIMM 6-1 to see if the motor turns. If not, check the harness connection between the main motor and the PCU PWB. You may need to replace the main motor, the harness or the PCU PWB.
Sharp error code l4-01
Main motor Lock, check Main Drive , and resistance contributed by all other applicable units
Do I need to input code after chenge new toner?
http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/MFPsPrinters/Manuals/cop_man_ar235_75.pdf Go to page 82 for instructions, no code is needed to be inputted after changing toner.
Service F1-15
Your finisher lift motor is not functionning well,just check it?
