SOURCE: Jenn-Air JGD8130 Gas Cooktop will not ignite
I just ordered one of these---sounds like people are not happy with this model---please get me more info
SOURCE: igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
SOURCE: Our Dacor gas cooktop igniter won't click.
Go to RepairClinic.com and check on how much a new igniter is. Is there two or 4 igniters on your model (lift the top of the range up and it is the little silver piece sticking out with a white base around it), If its 2 is the other side working? Make sure there is no food deposits around where the gas and the spark meet.
SOURCE: replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
SOURCE: GASS COOKTOP-electric ignition sparks continuously w/gas is of
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
