20 Most Recent AEG 23 in. 6410KF-N Electric Cooktop Questions & Answers
prestige induction cooker showing error p with beep sound problem solution
AEG 23 in.... | Answered on May 11, 2017
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
AEG 23 in.... | Answered on Feb 07, 2016
It is possible that there is fault in the circuit as the drive section seems to fault when the current requirement is high. It is also possible that there is a component possible a semiconductor- MOSFET- that has gone weak during the power outage and so fails .
It is best to have it checked now as it might save a larger expense if the whole unit fails. Also someitmes it can be a silly dry soldering which can be done up immediately. So get support if youa are not able to DIY.
AEG 23 in.... | Answered on Jul 22, 2015
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
AEG 23 in.... | Answered on Jan 20, 2015
Error Code: E3Reason: The voltage is higher for 3 secondsSolution: Check voltageSource: Induction Cooker Error Codes Explained
AEG 23 in.... | Answered on Jan 30, 2014
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
AEG 23 in.... | Answered on Jul 02, 2013
AEG 23 in. 6410KF-N Electric Cooktop Logo
59 questions posted
Top AEG Cooktops Experts
Marvin
Marvin
Paul Carew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
View Most Popular
AEG Cooktops
  • AEG Cooktops
Most Popular Question
prestige induction cooktop showing e3
  • Cooktops
