20 Most Recent
GE 30 in. JGP336 Gas Cooktop Questions & Answers
GE ZGU650 EM1BG Gas Cooktop
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
How do I raise the cooktop
on mine I just pull up on front egde and it will raise. There is an arm that will catch to hold it up while cleaning.
Gas cooktop never stop clicking
Hi mikegou100,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
I am looking for ignation switch
Usually, the igniter is contained in the same switch ( control knob) as the gas flow. When you turn it on, you should hear a clicking noise. I've never seen one of these with a separate ignition system.
Sorry if that's not the problem
tokfm
