Washing Machines Logo
V
Vicki Cole Posted on Jan 12, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm need to order carbon brushes for Maytag front loading washer. Model #MHWC7500YW0. I don't know the part number.
ray gallant
Level 3:
Top Expert:
  • Maytag Master 74,163 Answers
  • Posted on Sep 19, 2021
ray gallant
Maytag Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
657747
Points
561709
SALL YOUR LOCAL DEALER
5 Related Answers
Anonymous
  • 1028 Answers
  • Posted on Aug 10, 2008
SOURCE: How do you remove the
clips just under front edge and about 3-4 ins from corners press in with putty knife lift top remove screws on upper edge either inside just below top or along top edge
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Dec 03, 2008
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Anonymous
  • 398 Answers
  • Posted on Feb 19, 2009
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Anonymous
  • 1304 Answers
  • Posted on Oct 10, 2009
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Anonymous
  • 298 Answers
  • Posted on Dec 21, 2010
SOURCE: I have a maytag NEPTURE
you can try to reset it by unpluging for about 15-20 mins to let it reset itself. hope that works.
My magtag washer leaks only when i am filling it
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. I will also need to know whether it is a top load or a front load. Thank You. You may need to re-ask the question with the model number and serial number or message me at [email protected] because I am a certified appliance repairman and have repaired quite a few Maytag washers.
I want to change the carbon brushes, what type are the screws that hold thd the brush casing to the motor?
The screws are normally a pozidrive type, so you will need a pozidrive screwdriver.
Having said that, there ihas been more than one type of motor fitted to this model,
and one type does not have screws securing the brushes, they are clipped in place, so you will not know until you remove the motor from the washer.
4helpful
4answers
I have a Bosch Nexxt 100 Series WFMC1001UC/05 Front Load Washer that the brushes in the motor are wearing out. Were can I buy a set of brushes at? Any information would be helpful.
Part number is 154740 around 36 dollars from http://automaticappliance.com/ How to video from YouTube http://www.youtube.com/watch?v=N_r8d93xPYw&feature=youtube_gdata_player Different model washer but same motor. Look up videos for how to replace the belt if you have trouble. Symptoms of worn brushes include weak or no spinning.
Washer won't do anything. was washing a large comforter and the washer stopped working in the middle of a spin cycle. water did drain. now won't turn back on...no noise or anything. fairly new washer only...
If there is any voltage on the power group, try it temporarily with another device, if there is a control light on the display and it burned then read this suggestion.#
Its written by Hitachi but its on all kind of brushes made by other brands to find .
Carbon brushes are one of the most commonly replaced power tool parts. This is because carbon brushes are wear items, meaning that through friction and use they will gradually wear away until they need replacing. Worn brushes are a common causes of intermittent motor function, reduced electric braking and reduced motor power. A worn-out brush will often be worn down near to the wire lead and can be cracked, pitted, or burned. When replacing carbon brushes, be sure to inspect your armature for burns, cracks, or other damage which can indicate larger motor problems. [ NOW COMES THE IMPORTANT THING what i suggest ]
This Brush will pop out a pin when the Brush wears to a certain length.
It is advised to keep an extra set of these brushes on hand at all times
2helpful
2answers
My Maytag Neptune washing machine won't spin in the spin cycle
it may be the carbon brushes on the motor worn down, may need to replace, ideally the black carbon brush needs to more than 10mm if less the brush are struggling to have contact with the armature of the motor
3answers
Washing machines
sounds like your belt may be loose or the timer control maybe worn out
3helpful
3answers
Asko w6021 washer not working
replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
