SOURCE: copier will not print documents
turn off copier on the left side lower left to the rear there is a cover with one screw holding it in. remove screw and cover behind it is the waste toner bottle.. Empty bottle then at the top of the bottle is is 2 little circle indents (windows) clean those indents inside and out put bottle back in turn on copier that should do it good luck
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
SOURCE: Our Image Runner says there
The troubleshooting procedures that follow are organized according to location; to find out the location and the nature of a jam, use service mode (COPIER>DISPLAY>JAM).
