SOURCE: no lights on the control panel
check the thermal fuse at the control panel, the door switch, or the electronic control.
SOURCE: Control Panel Issue
sounds like a contorl board issue it might be going out i suggest get a repair guy out to fix it u can use our directory to find someone near u
SOURCE: Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
SOURCE: Reset control panel
If the clean light blinks 7 times and pauses,you have a problem within heat circuit,inspect the element for cracks or breaks.The actual door latch could be out of alignment also find the latch and bend it downward ever so slightly to assure good connection at door switches. To clear code push hitemp-airdry-hitemp-airdry,this will allow you to run cycle if code comes back,you may need servicer.
SOURCE: Ice maker in (kenmore )
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
