I had my fuel pump replaced because the mechanics said i had a bad fuel pump. The fuel fuse still kept popping. However; i noticed that the car manual for 1999 2.2L calls for a 20 Amp fuse but my panel on my car calls for a 15 Amp. Can this be causing the fuse to keep poping?
Also; I placed a 15amp fuse between the fuse box and the fuel pump and the fuse does not pop there only at the fuse box. I also replaced the relay but it keeps doing it.
Any Suggestions?
Thanks for the reply. I spoke with the manufacture and they said not to place a higher fuse or it would cause a fire. However; I went out and bought a meter that reads current which cost me about $40.00. I traced the issue back to the battery terminal which made no sense because i had just cleaned it from corrosion. I decided to replace the terminal and when i cut the cable; there was corrosion. I then cut it open about a foot and the entire line was bad. I replace the battery cable and my fuse stopped blowing. Hope this helps anyone else.
