SOURCE: Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
SOURCE: My Shark Pocket Steam Mop suddenly stopped
Here
may not be getting steam to the head...
Euro-Pro
Here
Manuals
that you need.
heatman101
[][];';'l;
SOURCE: Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
SOURCE: my shark steam mop handle broke, is there anyone
i know of a great site that sells all kinds of shark parts check it out
http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok
SOURCE: My euroflex monster 1200 steam
I'm assuming that you have checked the water inlet at the bottom and steam spout for lime or other deposits that can clog them - and cleaned them if necessary.
The steam is generated by the boiling of a small amount of water then the pumping of an additional amount of water in the steam spout. In your case the valve that controls the steam is defective.
There are no replacement parts for this unit - it's a service-free device: if something breaks inside it you just junk it and get a new one. If you want to try to fix it you will have to crack open the casing of the boiler (glued in there) access and replace the valve and glue it back together. It's a long and fiddly job for which you will need the spare parts recovered from another defective unit.
