Tip & How-To about Vacuums
I saw a post about no steam coming out of the head of a Shark Steam Mop. So I had to go and checkout my wife's shark....
Here is what I found and how you can check it out and fix it
If you pull the attachment off and look inside you will see that there is a small hole that the steam travels through into the flexible hose with the spring around it and then on to the head and out the smaller holes...
Now if the first hole gets plugged then no steam will get through to the head...however if there is something stuck in the hose or the smaller holes in the head are plugged it still could act the same...also check that the hose has not come off... there have been cases of the hose coming loose then the steam will not get to the head....you may have to remove the head to actually see that it is not connected properly.
So, first look right inside and check that out, then if that is okay, take out the four screws that hold the swivel joint into the head...then you can take out the last two screws holding the swivel joint to the head...
This will allow you to blow back through the hose to make sure it is not obstructed or to blow the dirt back out... a small wire or pipe cleaners will also work well.
If that is open the take a tooth pick or some small like that and open the holes in the head....blow through the head to make sure that they are open, try to make sure all of the holes are evenly opened so that you get good distribution of the steam to the whole head.
Then replace everything back like it came apart...make sure that you replace the two screws first then drop the swivel into the slots and replace the four screws.
Reinstall the head onto the mop and give it a minute or so to heat up after plugging it in.
Now the steam should be going out the head like it was intended...
If you still do not have any steam from the mop then the heating element has probably has gone bad. As far as I can tell there are no heating parts available for these. You will have to junk your mop and buy a new one.
The mop does have a 1 year warranty and details of that are on the link I have below for the manuals.
All of the Shark Manuals and much more, can be found by clicking on the highlighted text
heatman101
Check out these other related tips...
http://www.fixya.com/support/r6740629-shark_steam_pocket_mop_cleaning_problems
http://www.fixya.com/support/r6896271-find_shark_parts_accessories
Here
is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it
may not be getting steam to the head...
Euro-Pro
Shark Steam Mop Problem
Here
also is a link to get any of the Shark
Manuals
that you need.
heatman101
Here
Euro-Pro
Here
Manuals
that you need.
heatman101
