Brother DCP 130C All-In-One InkJet Printer Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Init unable 4f
The dcp-130c 3 in one printer not working. message appears on the printer screen is init unable 4f. pliz help me. iam really in need to use my printer.
  • 3 more comments
  • Anonymous Mar 13, 2014
    Message stuck on
  • Anonymous Mar 15, 2014
    UNABLE TO INIT.4F
  • Anonymous Mar 17, 2014
    deapues de hacer todo el prosesa me sigue saliendo unable init 4f
    unable to init. 4f
  • Anonymous Mar 27, 2014
    i am trying to print my documents
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Aug 31, 2009
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
31810
Points
250
Uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
  • hasanali
    hasanali Mar 14, 2014
    how rimov 4f
I have a problem with "brother DCP-J140W" printer, it shown at the LCD "Init unable 4F" i was thinking the problem must be the printer head, can it be repaired or just replace the head ?
Hi
Error 4F means your printhead is RIP, mostly due to bad quality ink, the only one way to fx the printer is changing the printhead but... is that really worth it?
Well, check on ebay.com or isscx.com if you can find your part at a good price!
Best Regards
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Unable init 4f
the dcp-130c 3 in one printer not working. message appears on the printer screen is init unable 4f. pliz help me
Brother DCP-130x - unable to print, error code 4F - How to fix it?
unable to print 4f means, theirs a problem in the printer head.. the best solution for your printer is to replace new printerhead.
1helpful
Init unable 4f .. try to uninstall printer and then reinstall still nothing has happen the same thing seems to appear on the screen .. printer is brother dcp130c please help
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Como posso corrigir erro impos impr 4f brother dcp 130c.
4F message indicates that the printhead is RIP, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
4helpful
My printer says unable 4F clean
4F message indicates that the print-head is gone, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
7helpful
2answers
I get a message stating unable to init. 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Norman Weimar
Norman Weimar
k24674
