HI.
When I connect my HP Printer thru Usb to any Usb port in my Acer Aspire 6930G Laptop , it shortcircuits my house electric instalation.
Any other usb device connected does nothing and works fine. The same printer connected to my other older (5years) Acer laptop works fine!??!!!
Any ideas about this problem!?
Hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Testimonial: "Thanxs"
I don't think is the printer, you said it works with an other computer (PC).
Sometimes laptop usb port may not have enough power to communicate with some devices hence the external power usb hub will help.
If all fail try contacting the printer supplier, they might know about this issue and if so they should provide a solution or get your money back.
regards
tekspotDotCoDotUk
it's hard to say.. it could be just some bad windows system files in your laptop
I tried a different usb cable , but it happened again.
I´ll have to try to get a powered Hub to see.
But in your opinion the problem is with the Printer , right!? Not the laptop !?. I ask just to know if it´s worth taking it to where i bought it...
