After recharging the battery, when I try to power on the device, the easyshare splash screen appear and a green light shows on top then it suddenly change to red and flash two times then turn back to green again and the kodak shutdown. When I try to power on, the lens is not coming out as usual. Can I do something to repair it?
Still wont come on after cleaning
The problem you describe is frequently the result of dirty/corroded
battery contacts in the camera. Try removing the batteries and
cleaning the inside contacts with a fine wire brush, steel wool, or
fine sandpaper. Remove any residue left from the cleaning, then
replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
