20 Most Recent Kodak EASYSHARE M763 Digital Camera Questions & Answers
My camera turns on then turns right back off again?
Same thing happened to mine, and it had to be sent away for repairs.
5/8/2017 4:10:33 AM • Kodak EASYSHARE... • Answered on May 08, 2017
When I power up the
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
4/4/2015 5:29:20 PM • Kodak EASYSHARE... • Answered on Apr 04, 2015
My camera will not recognize the SD cards that I have used for thousands of pictures. Is this fixable. The SD cards check OK in other equipment.
This happened to me once, somwhow file structure on SD card gone wrong. if no files on sd card it is better to format it on several devices consequently, then on your digital camera.
12/2/2014 8:45:59 AM • Kodak EASYSHARE... • Answered on Dec 02, 2014
Kodak troubleshooting
If the deleted pictures were on a memory card and you haven't done anything with the card since you deleted them, maybe. Do a Google search for "data recovery software." Pick a program appropriate for your computer or operating system. Take the card from the camera and put it into a card reader attached to your computer. Cross your fingers and run the program.
9/1/2014 4:21:54 PM • Kodak EASYSHARE... • Answered on Sep 01, 2014
How to upload pictures to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
7/29/2014 5:53:51 AM • Kodak EASYSHARE... • Answered on Jul 29, 2014
Charger quit working after two months, I need a
One source for third-party chargers for the KLIC-7001 battery is http://www.overstock.com/search?keywords=klic-7001&SearchType=Header
8/8/2013 11:14:16 PM • Kodak EASYSHARE... • Answered on Aug 08, 2013
My kodak Easyshare M763 camera turns on, the lens comes out and opens and the display screen lights up but remains white and I can't see through the shutter. I thought it may be a bad LCD display
I think I already answered you but here is the problem, sounds like the main board that processes the image just like your television has.
1/24/2013 11:19:59 PM • Kodak EASYSHARE... • Answered on Jan 24, 2013
Does anyone know what could be wrong when a digital camera turns on and the display lights up but remains solid white and you can't see through the shutter?
The problem sounds like the main board that processes the image just like the one in your television. Shop time.
1/24/2013 11:03:29 PM • Kodak EASYSHARE... • Answered on Jan 24, 2013
The whole camera and battery gets hot when charging
Charger is faulty. Check your charger by technician.
8/8/2012 12:36:46 PM • Kodak EASYSHARE... • Answered on Aug 08, 2012
How do you reset this camera
Remove the battery for 15mins.then insert the battery go to the menuu setting and set the Date and Time.
4/8/2012 11:22:55 AM • Kodak EASYSHARE... • Answered on Apr 08, 2012
High camera temperature camera will be turned off
We see this happen at my photo store when there is a battery issue. Something like that will more then likely need to be sent off for repair.
11/27/2011 8:38:07 PM • Kodak EASYSHARE... • Answered on Nov 27, 2011
Can't download pictures on to
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
9/14/2011 7:30:27 PM • Kodak EASYSHARE... • Answered on Sep 14, 2011
How do I turn the
1 Press the Menu button.
2 Press to choose a tab:
3 Choose 'Capture' for the most common picture-taking settings.
4 Press 'Down Key' to highlight Date Stamp and turn it off.
8/15/2011 11:33:49 AM • Kodak EASYSHARE... • Answered on Aug 15, 2011
Ive charged the batteries but it still wont switch
Even with new battery if the camera does not trun on then there is fault on the main control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck that seems to switch off the controller..
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre as it might be the processor controller section which is the main board that is suspected.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
7/26/2011 10:14:13 AM • Kodak EASYSHARE... • Answered on Jul 26, 2011
Need to change date on
In any mode, press the MENU button. Use cursor-left/right to highlight Setup and press the OK button. Use cursor-up/down to highlight "Date & Time" and press OK. Use cursor-left/right to move between fields, cursor-up/down to change them. Press OK when done.
Here're the pages from the manual:
http://resources.kodak.com/support/shtml/en/manuals/urg00810/urg00810c4s2.shtml
http://resources.kodak.com/support/shtml/en/manuals/urg00810/urg00810c1s5.shtml
7/19/2011 4:27:30 PM • Kodak EASYSHARE... • Answered on Jul 19, 2011
When I press the power
Lens error, you need to get it fixed or replace. Very common problem on these telescoping lens cameras.
7/18/2011 4:23:38 AM • Kodak EASYSHARE... • Answered on Jul 18, 2011
How do u charge a kodak 7.2 camera, using the usb
Use the USB cord to connect the camera to a powered USB port on a computer. Do not connect it through a USB hub. Be aware that not all computer USB ports put out enough current to charge the batteries.
6/17/2011 7:32:44 PM • Kodak EASYSHARE... • Answered on Jun 17, 2011
When I hook my camera up to my laptop the pictures
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
5/1/2011 12:10:48 AM • Kodak EASYSHARE... • Answered on May 01, 2011
Kodak EASYSHARE M763 Digital Camera Logo
114 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
need change date
  • Cameras
