SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
SOURCE: Describe your F6212-900 / F6215-900
I took out all of the screws in the housing, separated the left side from the right from the handle down. There were three screws on the underside of the upper unit. (right where the tanks sit). O those were out I could finally get to the broken hose.
go to shark in GOGGLE. Go sharks wedsite, find your vaccum, click your hose. We have 3 mops and vacuum. No trouble getting parts and filters. Not high priced.
Hi, it's Cindy from Crucial Vacuum.
The small hose on the head of the vacuum cleaner can be easily detached and replaced! It's best to remove the bottom of the hose first before removing to top. So grab onto the bottom of the hose and pull it out of it's socket. Then you have a clear view of the two tabs on the top of the hose. Push down on both sides and pull. It may require some strength to get it the tabs out from it's holder.
When replacing the part, look for part number 193FFJ. You can purchase direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark-navigator-lift-away-floor-nozzle-350-series.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
SOURCE: how to release a stuck wand in a shark dust away rotator vacuum?
very difficult
it can be done if you have access to a vice
place the smaller wand section in the jaws so that it slips easily but the larger part is stopped by the vice jaws
a sharp pull will break the seal effect and it will pop apart.
if the wand is metal you can enlarge the outer part at the joint by applying heat carefully with a gas lighter for a few seconds and pulling apart
