I would check the wires and push to talk switch for your microphone. Likely the continuity is broken due to either a broken connection at the plug, the wire itself, or the push to talk switch. Use an ohm meter with the microphone unplugged and put the two test leads of the ohm meter across the two pins on the microphone plug that controls the on off function. When you press the push to talk switch if the ohm meter does not read near zero ohms, your problem is in your mic connections,
SOURCE: gALAXY 66 OFF FREQUENCY ON AM ... HELP
These radios have a complicated synthesizer circut in them to create the operating frequency and are not easily aligned without the aid of very expencive equipment, Which must be kept calibrated! Call 7086 270 3829 they are Galaxy Experts and have that equipment which is kept in certified calibration, Service monitors, Spectrum analizers and all.
