20 Most Recent
Galaxy Radios DX-33HML 40-Channels Base CB Radio Questions & Answers
I have a Galaxy DX 33 HP CB radio, but i have
Google search suggests it's a 10m HAM radio. CB radio is on a different frequency (around 11m)You might take a look at this page which looks like it is talking about how to convert this radio to CB.http://www.cbtricks.com/radios/galaxy/dx33hml/dx33hml_freq_conv.htm(Disclaimer: note that it's illegal to run more than 4W on CB channels in the US)Hope this helps
On the high side it
could be a number of reasons but the first place to check is the mic then proceed from there.
Want talk no eco or talk back
go to www.cbtricks.com and look for galaxy DX radios find yours and there is a topic that will tell you how to dismantel it.
How to tuen and turn up
there should be no reason to tune it . Its just an extra that everyone thinks they need Now to turn it up is a different answer. Go to www.cbtricks.com they have the manual you will need to turn up the power and the modulation.
My galaxy 33hml has low recsive and the rf gain dont work
have you played around with anything on the inside of the radio??? there are variables on the inside for hi and low power also hi and low modulation RF gain and the such if you turned the wrong one the wrong way,poof thats it. It can still be fixedbut not by you.
Galaxy 98 mic it shocking me
rf voltage do not use the mic.try another to see if it does the same thing .If it does then take it to a tech to have them check it out.
Galaxy dx 33HML
you played with it ,now take it to a tech and let him tune it for you.
Tx rx
the problem you now have is probably going to cost you more money to fix than the radio is worth. Could be a quick simple fix or you could be at it for hours trying to fix it. you will need a scope, frequency counter,watt meter, modulation meter, signal generator, volt meter,distortion meter,and a service manual from
www.cbtricks.com
I have a galaxy dx33hml with 120 channels im trying to tune it to regular channels how should i do this
The hml has not been in production since 2006. If you Love that specific radio the first thing I suggest before attempting to tune or mod replace all the capacitors they may have leaked or dried up especially if left uncovered for a long period. But I would not bother when the galaxy 33hp2 updated the model with dual finals for under a couple hundred dollar. The radio is easily converted with info you could gain from here or a cb forum.
