20 Most Recent
Galaxy Radios DX-959 40-Channels Base CB Radio Questions & Answers
Unit will not power up.
the board may have loose connection on the voltage regulator.. if not may have blown the protection diode. IF you need help let me know.
Kl 203 rm italy linear amp transmitt
You just have to lower your RF power so that the radio is putting out about a 2 watt dead key. Any higher and you will over drive the finals and burn out the final
Galaxy 98vhp no modulation am
Turn up your mike gain. Mod the beans out of it and that should fix your problem. Crank every screw you can see on the board and wash it out with soap and water. This will fix it good.
External jack
sounds like you got a good radio to practice on . If it was given to you then you have nothing to loose except what ever you put into it. try hooking the speaker jack back up, see what it does??
