SOURCE: rubbing or grinding noise in steering wheel
Hi, this could be a combination of many issues. i would check the following.
Check the strut mounts. there could be some damage here concerning the mounts. i would also check the control arm bushings as well. check for damage here. I would also inspect the CCV half Shaft as well. this is a known problem spot(re manufactured)CCT.
The last problem spot here will be the actual wheel bearings in the front. they may be worn or dry. this could cause the symptoms you stated as well.
you will find the issue in one or all of the above problem spots stated.
Please rate and god bless:)
SOURCE: my car makes a scrapping and or grinding noise when driving and braking like i'm dragging something
Just by the information you put, I would say its your brakes. They are most likely worn out past the minimum wear (3mm). If its whenever you drive maybe you are dragging something? Your exhaust system supports may have failed, maybe something stuck in there and so you are dragging it along. Take a look underneath your car.
If the noise only happens when you brake then its gotta be a problem with your brakes. Sometimes rocks get stuck in between brake pads and rotors, this makes a very annoying squeeling sound until the rock comes loose and falls out. Another possibility, like I said earlier, is that your brake pads have worn out and is now metal on metal. I recommend you go to a shop and get your brakes checked. Brakes are a very important part of your vehicle, safety especially, so I don't recommend doing it yourself unless you know what you are doing.
Hope this helps.
Thanks
SOURCE: 2002 Mountaineer SUV, 4WD, Especially while turning the wheels
I had the same problem with my 2002 Mountaineer at about forty thousand miles. Murcury replaced the steering column free under warranty. I now have ninty two thousand miles and it's back. The rear end is making a whining noise, the tranny is starting to slip, and the rear window regulator went out. Why did we buy a Mercury?????? Disgusted Dave!!!
SOURCE: 1988 Subaru dl wagon transmission
check those front hub bearings ...gotta pull the axle out and the brakes apart...there is a pair of roller bearings inside the hub which the outside cv axle rides on..do get the axle nut back to 160 foot lb with the washers in place
SOURCE: Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
