SOURCE: DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
SOURCE: Dehumitifier wont condense water
This happened to me after the unit was turned on after being off all winter. I've had it just two years. After speaking with "support" I gather that it needs a new condenser, perhaps just because the freon may have escaped. It may be a sealed unit. Anyway, the math works out to simply discarding it and buying a new one. For me, this means not buying a DeLonghi. By the way, their service centers are strategically placed in remote areas to attract the fewest claims HD
SOURCE: My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
SOURCE: i have Delonghi DE500P dehumidifier was running
First, make sure the humidistat isn't set too high by adjusting it to
the lowest humidity setting and running it again. Next, test the
dehumidifier by placing it in a closed bathroom with a hot shower
running. If you don't see water collecting in the unit after several
minutes, turn the unit off and clean all dehumidifier filters and
coils. If, after adjusting the settings and cleaning the unit, you
still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Good luck
SOURCE: DeLonghi DE500p quit. Won't light
I am glad to HELP YOU!
If the light doesn't work while plugged in that means the compressor is out and it has to be replaced.
Anyway I've found for you the components HERE [the drawing can be printed and you can show it to an electrician if you will decide to fix your device...] and above the drawing, in BLUE, you have a link [called OWNER'S MANUAL] to the... manual, of course. It's downloadable in PDF format [you will need Adobe Reader to visualize it].
Or you can take the manual from HERE and the Adobe Reader from HERE.
I wish you all the best!
