Garden Logo
V
Valerie Bayliss Posted on Apr 16, 2018
Can I get a replacement trigger and hose for my PRO1600 PWA power washer ?
P1800s power to the pressure washer. moter does not come on
When the power washer does not turn on, it is either due to no water flow or no electricity going to the power washer. In other words, either a water or electrical problem.
check water flow issue like this
  1. The high pressure hose, spray gun and lance must be connected to the power washer.
  2. The garden hose must be connected to the power washer using the garden hose adapter.
  3. Turn the water completely on at the water faucet.
  4. The power cord should not be plugged in.
  5. Squeeze the trigger on the spray gun.
  6. If there is water flow through the spray gun and lance shooting 10 - 25 feet, this confirms water flow is NOT the problem for the power washer not turning on.
  7. If there is no water flow, perform the following troubleshooting procedures:
    a. Remove the lance, squeeze the trigger. If water flows, the lance is blocked. Use cleaning wire to clean the nozzle tip and try again.
    b. If no water flows with lance removed, turn the water off. Remove the spray gun from the high pressure hose. Turn the water on, if water flows, the gun is the problem. Reattach the gun, turn the water on and squeeze the trigger. Sometimes this unblocks the gun. If not, replace the spray gun.
    c. If no water flow with the gun removed, remove the high pressure hose, turn the water on to make sure there is no blockage in the hose. This is very unlikely but we need to make sure.
    d. If no water flows out of the water outlet, the quick connect garden hose adapter is problem. See Garden Hose Adapter troubleshooting.
  8. For electrical solution check
  9. The power switch was not turned on. Find the power switch and make sure the "-"side of the rocker switch is pushed down. "O" = Off and "¾" = On.
  10. Next, make sure the power cord is plugged directly into an outlet and NOT into an extension cord. The directions do say not to use an extension cord.
  11. Each time the power cord is plugged in to an outlet, the Reset button on the GFCI module must be pressed down to connect to electricity.
  12. Check to see if the Reset button has been pressed.
  13. Next, confirm the small plastic window below the Reset button shows RED in the window. The RED color is not a light but a RED screen that slides into the window when the Reset button is pressed down. Because it is not a light, it can be hard to see in low light. If you are unsure, press the TEST button down. If the GFCI was set and RED was in the window, you will hear and feel a "click."
  14. The RED color must stay in the window once the button is released. This confirms there is electricity going to the power washer.
  15. If the RED color goes away when the Reset button is released, there is NO electricity going to the unit. Try another outlet until the RED stays in the window.
  16. Now if the unit turns ON for a second or two with the Reset button pressed and the power switched on, it is working as it should. All that is left to do at this point is to squeeze the trigger on the spray gun and the power washer will turn on. When the trigger is released, the power washer will turn off. This is due to the Total Stop System (TSS) that only turns the unit on when water is flowing through the power washer. When the trigger is released, water flow stops which the TSS sensed and immediately shuts the unit off. a) So to review, if the Reset button has been pressed and is holding and the power switch is ON, the power washer is supposed to start up for a second or two and immediately shut off. At this point all you need to do is squeeze the trigger; the unit will turn on.
Oct 24, 2019 • Garden
I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
Apr 19, 2014 • Garden
8helpful
3answers
When start machine then display shows call for sevice F14
F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Low pressure from powerwasher wand when trigger is squeezed
THIS POWER WASHERS ARE TRICKY, TO OPERATED YOU NEED TO OPEN THE WATER FAUCET CONECTED BY A HOSE TO THE POWER WASHER , OPEN THE TRIGGER AND THEN START THE POWER WASHER, OTHER WISE YOU WILL RUIN THE POWER WASHER PUMP.
1helpful
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
3helpful
Toshiba e-studio 160, c56 error code.. how can i reset this code.. pls help me..
C56 indicates Communications error between the PFC and the CPU on the main PWA. What u can do:
1.Check if the connector CN36 or CN35 on the relay PWA is disconnected.
2.Check if any conductor pattern (PFRXD, PFREQ, PFACK, MACK/PF, PFTXD, or MREQ/PF
between the IC, IC2 and CN36) on the relay PWA is open- or short-circuited.
3.Replace the relay PWA.
4.Replace the PFC PWA.
5.Replace the main PWA.
1helpful
2answers
Trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
7helpful
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 • Garden
Top Power Washer Garden Experts
Paul Bade
Larry Ng
Larry Ng
Steve Pack
Steve Pack
Are you a Power Washer Garden Expert? Answer questions, earn points and help others
