20 Most Recent Power Washer 1850 PSI Electric Questions & Answers
MY 1850 PSI POWER WASHER WON'T START UP. As fast as the motor started, it shut down. And there is still power. What is the problem?
Probably a clogged carb from sitting all winter with fuel it it.
11/26/2014 2:13:08 AM • Power Washer... • Answered on Nov 26, 2014
2answers
Just filled power washer with gas, changed spark plug and added oil, now it's smoking white and seems like it wants to turn off, what do I do?
add oil to what, not told? no maker or model told , impossible answer lacking ESP never put oil in a 4stroke engines gasoline tank. never over oil a 2 stroke, if tells 50:1 do so and win. not more. 50 parts gas to 1 part oil or buy fuel from walmart called premixed 2 stroke gas. no washer told of vast ,zero.
7/31/2022 6:00:37 PM • Power Washer... • Answered on Jul 31, 2022
Parkside power washer has no pressure at gun I have cleaned the unloaded valve CAN I put a smear.off grease on to the valve
you can . How do you unloader valve is bad? The pump is the most probable cause. the discharge valve(s) are leaking. It is a disposable unit.
12/1/2021 3:17:37 PM • Power Washer... • Answered on Dec 01, 2021
My electric power runs for a few seconds then shuts off. If I remove the power nozzle the engine works with the open wand. How can I get it work
Check all ends of your power wand. there should be a little filter and if it gets plugged the motor will shut down. Check both ends of your wand. The sprayer end should come off and mine has a filter if you take the sprayer end off.
8/20/2018 1:16:39 PM • Power Washer... • Answered on Aug 20, 2018
0answers
2answers
Is weed membrane fabric any good for applying to stone driveway
Ensure the membrane is protected with sand before laying the stone to avoid piercing the membrane.
4/24/2024 11:53:02 AM • Garden • Answered 5 hours ago
Power Washer 1850 PSI Electric Logo
1 questions posted
Top Power Washer Garden Experts
Paul Bade
Larry Ng
Larry Ng
Steve Pack
Steve Pack
Are you a Power Washer Garden Expert? Answer questions, earn points and help others
View Most Popular
Power Washer Garden
  • Power Washer Garden
Most Popular Question
1850 psi power washer start up as fast
  • Garden
