After cutting for a few min the lights comes on. I have changed the hidrolic oil and filter, new belt and replaced the tention for the belt and new oil cap. Battery was not holding a charge for long so replaced battery, clean termals.
Hey Joe,
Are you sure it's the hydraulic oil low pressure or is it the engine oil low pressure light? Check the engine oil for being low, over full, filter change, right type of oil, leaks, air filter, spark plug, clean air intake, battery getting a good charge, if that stuff is ok, then find your oil pressure switch and change that out.
But it if it is the hydraulic oil light, check for leaks, that is a high pressure system so don't put your hand by hydraulic leaks use cardboard or something to check for leaks, a pin hole leak can cause severe damage to your skin from a high pressure injection from fluid.
Let me know if this helps and we can go from here
SOURCE: Low Oil pressure light in idle at stop
Depending on the amount of miles, maintenance records, or how hard the car has been driven either by a previous owner, or by yourself. The engine's main crankshaft bearings or the connecting-rod bearings could be excessively worn.
Also, it could very well be a wiring problem to the sensor and/or computer causing the problem.
SOURCE: oil pressure light on
Yes I believe there is!! I can't think of it right off hand.I will look it up and get back to you. Also have you checked to see if your spark plug seals are worn. I am replacing mine now.I had an issue with the engine light coming on at certain revs!!!
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
SOURCE: OIL PRESSURE LIGHT INTERMINTENLY GOES OFF AND ON
Keep checking those Fluids. it sounds a lot like your Oil pump is taking a Slow Death March. At some point you will need to replace it.
SOURCE: Oil Pressure Light Comes On after 10 min of Driving
You may not have put the right amount of oil in your car, your oil pressure sensor could be faulty, or you may have a leak.
By revving your engine, you're increasing the pressure and thus turning off the light and making the sensor think that it's at the correct pressure.
SOURCE: 2002 Ford Escape V6. Oil indicator light on, but pressure holds.
My 2002 Ford Escape had exactly the same problem as described. Dealer replace oil pressure sending unit (oil pressure switch) and problem still existed while leaving dealer about 3 miles away. I took the car back to the dealer again in two days and the oil pressure light kept of blinking sporatically all the way to the dealer. Dealer checked connections and they drove the car around and the oil pressure light never came on. I picked the car up from the dealer and I've had no problems with the oil pressure light flashing. I wonder if there is a microprocesser in the oil pressure sending unit which has to be given some time to be recalibrated to the cars main computer module?
