My oven is ot of service. I have to use the toaster oven and need to know how to cook or bake stuffed bell peppers in the toaster oven. Thanks for any help.
SOURCE: What is exactly a toaster oven?
A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
SOURCE: broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
SOURCE: Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
SOURCE: Need manual for operation of this toaster oven
Here's the link for your manual, in pdf format:
http://useandcares.hamiltonbeach.com/files/840148700.pdf
Please rate if this helps :)
SOURCE: burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
