20 Most Recent Oster 6071 Toaster Oven with Convection Cooking Questions & Answers
4answers
Need knobs for Euro-pro convection toaster oven TO161
Take a look here Amazon com euro pro toaster oven on amazon. I'm pretty sure you can find something. cheers
1/4/2018 6:29:01 PM • Oster 6071... • Answered on Jan 04, 2018
Need the temp knob can find also need the rack.
Try the list of sites that the following address will give you:
1642992.jpgnetshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
ToasterandConvectionOvens.com
2/10/2011 4:56:05 PM • Oster 6071... • Answered on Feb 10, 2011
6answers
The knob on the bottom
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
11/8/2010 8:21:35 PM • Oster 6071... • Answered on Nov 08, 2010
Knobs are broken. Need new ones
here is what i just did with mine that i bought used, i put some jb weld into the socket of the knob and i am waiting to see if it will be a success! it is an idea though. have to give me credit for trying. mine was the timer knob. jerry
2/5/2010 2:41:53 AM • Oster 6071... • Answered on Feb 05, 2010
How to remove the cover on an oster toaster
re: Oster TSSTRTS2S2-033 disassemblyHi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off. I hope that helps.JimmyHaulinHogs
2/25/2023 7:25:09 PM • Oster Toaster... • Answered on Feb 25, 2023
2answers
My Oster toaster oven heating element wont turn off when ready?
A faulty thermostat or temperature sensor could be the cause of your Oster toaster oven's heating element not turning off when ready. You can try the following steps to fix the problem:
  • Check the settings for the temperature control: Check to see that the thermostat is not set too high. The heating element may not turn off even when the desired temperature is reached if it is set too high.
  • Get the toaster oven clean: Check to see that the toaster oven is clean and free of obstructions. The heating element may occasionally malfunction due to dirt and debris. You can get oven cleaner, https://amzn.to/3xlDd86 .
  • Check the temperature: The thermostat or temperature sensor may be defective if the problem persists. To fix the problem, you might need to buy a new thermostat or temperature sensor.
  • Contact Oster's support team: You can get assistance from Oster customer service if the problem persists after attempting the steps listed above. They might be able to offer you a solution or point you in the direction of a repair company.
2/13/2023 2:58:10 PM • Oster Toaster... • Answered on Feb 13, 2023
5answers
Oster Countertop Oven Model TSSTTVCG04 won't heat on any setting. Any suggestions
Probable heating element or control failure
3/21/2022 7:34:07 AM • Oster Toaster... • Answered on Mar 21, 2022
2answers
Model TSSTTVXXLL. Can the timer be replaced?
The timer can be replaced if Oster has it available currently.
12/31/2020 2:49:49 PM • Oster Toaster... • Answered on Dec 31, 2020
Oster toaster oven is not working on the toast or warm settings. Is there a remedy for this?
Possibly a new element would cure it or thermostat.
12/16/2020 9:52:33 AM • Oster Toaster... • Answered on Dec 16, 2020
Need to find out the capacitor sizes on an Oster TSSTTVDG0 toaster over. One blew apart and all the info tag is gone
That information does not seem to be available. You would have to ask their service department. www.oster.com > toasters-and-ovens-ovens-manual
Want to Shop Your Favorite Products and Replacement Parts Online? Visit our Preferred Retail Partners · See Details Here · Home : Service & Support : Product ...
tssttvdgxl - Oster
www.oster.com > instruction-manuals
PDFTranslate this page This appliance has no user serviceable parts. Any servicing beyond that described in the Cleaning. Section should be performed by an Authorized Service ...
Search Results - Oster
www.oster.com > toasters-and-ovens-manuals > ovens
TSSTTVMNDG-001 - Oster® Large Digital Countertop Oven, Instruction Manual Download ... Download Manual ' Similar Manuals; TSSTTVDGXL - Download ...
OSTER TSSTTVDGXL USER MANUAL Pdf Download ...
www.manualslib.com > Brands > Oster Manuals > Oven
View and Download Oster TSSTTVDGXL user manual online. Extra Large Countertop Oven. TSSTTVDGXL oven pdf manual download. //
11/8/2020 12:45:52 AM • Oster Toaster... • Answered on Nov 08, 2020
How do I change the light bulb in Oster Toaster Oven Model 6057-000?
Telephone numbers for customer service assistance in online manual: https://www.manualslib.com/manual/498532/Oster-6059.html?page=16#manual
5/24/2020 5:41:18 PM • Oster Toaster... • Answered on May 24, 2020
My toaster oven Oster model TSSTTVXXLL is not heating. It's pretty new. Purchased in January or February.
If it is that new, then contact Oster for replacement or repair under warranty Do this before the warranty runs out though
11/15/2019 9:32:37 PM • Oster Toaster... • Answered on Nov 15, 2019
I received an Oster countertop convection oven as a gift but I cannot find a cord to it nor any place for a cord.
Suggest contact the people who gifted it to you and ask for the cord. Be careful when dealing with electricity.
10/1/2019 7:07:43 AM • Oster Toaster... • Answered on Oct 01, 2019
Oster 6071 Toaster Oven with Convection Cooking Logo
19 questions posted
Top Oster Toaster Ovens Experts
john h
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
View Most Popular
Oster Toaster Ovens
  • Oster Toaster Ovens
Most Popular Question
need knobs euro pro convection toaster
  • Toaster Ovens
