SOURCE: Transferring music to Insignia MP3 player
When using your media player... you need to first figure out if you are using windows media player 9 or windows media player 10. Also what windows are you using on your computer, that makes a difference as well... Make sure you have the mp3 player plugged in properly and then...Once you are in your windows media player go to your lib tab... soon as you are in there then on the right side there should be section on where you could build a lib list. Meaning you should be able to pick the songs in your lib and just drag them over. On the bottom you should see something that says sync... Once you've choose your songs and dragged them over... all you should have to do is press the sync button and it will do all the work for you from there. And it should let you know when its complete...mine does. Hope I could help you.
SOURCE: Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
SOURCE: deleting music
try making sure that your mp3 player isnt locked... i had the same problem and ijust had to unlock it
SOURCE: Windows Media Player 10
You can not play WMV or ASF media on a website with Internet Explorer's Media Bar turned on.
Internet Explorer has its own player for the Media Bar. To get around the c00d11cd error being generated you need to turn the Media Bar off. To disable Internet Explorer's (version 6) Media Bar click the Media button on the main Toolbar, then click "Media Options" in the new pane that opens. Now select "settings", and then un check "Play web media in the bar".
There is no need to restart your machine as this will take effect immediately.
You have a "playlist" on your PC that you are trying to copy to a CD-R. When you hit the copy button it goes straight to the c00d11cd error!
The most likely cause is DRM. Check the songs on your "playlist" to see if any of the content protected. To do this simply "right click" on each song, then select the "license tab". If any of the songs are protected then you can NOT copy them without the appropriate DRM authority. (DRM = Digital Rights Management) You will need to check with the site you purchased from to see the level of DRM used.
You have a "playlist" on your PC that you are trying to copy to another computer. When you try and play on the new computer it goes straight to the c00d11cd error!
The most likely cause is DRM. (DRM = Digital Rights Management)
It is likely you purchased and downloaded from a site Like Walmart.com Online stores like these set restrictions on what you can do with the .WMA files you download. It is likely that the DRM licence for your download restricts you copying to another PC. You will need to check with the site you purchased from to see the level of DRM used.
You can not copy songs from a CD in the CD drive to your hard disk. Windows Media Player generates the c00d11cd error.
The most likely cause is that something has gone wrong with the special file responsible for the "encoding". The name of the file is: wmadmoe.dll
The first thing we need to do is re-register this file with Windows XP To do this go to the "Start Menu" and select "Run". Now type in the following: regsvr32 wmadmoe.dll
If this does not work then the file itself may be corrupt. To fix this go to the "Start Menu" again and select "Run". Now type in the following: sfc /scannow
This will now scan your XP machine to see if there are any corrupt system files. If there are any then XP will prompt you for the XP CD so it can get a new copy... This may help you resolve the c00d11cd error.
This will get you up and running again, however due to some underlying problems with your installation you may actually need to re-install Windows Media Player.
Please rate this fixya
