20 Most Recent GPX HTD2204 System Questions & Answers
Samsung AV-R270
is there a software update for a samsung AV-R720?
6/6/2012 1:30:42 PM • GPX HTD2204... • Answered on Jun 06, 2012
4answers
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
6/10/2010 12:21:04 AM • GPX HTD2204... • Answered on Jun 10, 2010
Cannot get the surround to work correctly gpx dvd home theater
Check your setting it may be set to 2.1 or stereo. As for hooking up the tv check for aux or tv audio inputs on the dvd player and attach to the audio outs on the tv. You may need to change the settings on the tv, go to the audio menu on the tv and change from variable to fixed.
1/12/2009 11:24:36 PM • GPX HTD2204... • Answered on Jan 12, 2009
Where can I get repairs for fox c1600
In one part of you question, you state Fox C1600 and also GPX C1600 https://www.google.com/search?q=fox+c1600 https://www.google.com/search?q=GPX+C1600 All questions need full 'make model (what it is)', first 3 words. There are too many items with those numbers. ..
4/22/2024 11:34:25 PM • GPX Audio... • Answered 2 days ago
What watt speakers on GPX C1600 karaoke machine
I would say that as the output is 50Watts music power, a 50Watt speaker would be ideal.
12/26/2023 5:49:04 PM • GPX Audio... • Answered on Dec 26, 2023
GPX SP-60, 5.1 Home Theater Speaker System. I need an owner's manual for it please?
Unfortunately not available anywhere. There are too many items with parts of GPX and SP-60 in them. https://www.google.com/search?q=GPX+SP-60+manual ..
10/4/2023 3:17:24 AM • GPX Audio... • Answered on Oct 04, 2023
How to play cd in gpx cd clock radio crcd 6306 dt
How do I play a CD?
  • Make sure the clock radio is powered on. Once a CD is inserted, playback should start automatically. It may take up to 10 to 15 seconds before CD plays.
9/24/2023 2:16:05 PM • GPX Audio... • Answered on Sep 24, 2023
I own a GPX HM3817DT that does not work. There is no voltage coming out of the transformer. It could be a bad switch or transformer. How can I test either.
Hi 1st check there is voltage going into the transformer, if there is nothing coming out then the transformer is no goodIf there is no voltage going into transformer then check the fuse at the plug
3/31/2023 5:03:11 PM • GPX Audio... • Answered on Mar 31, 2023
My gpx mw240s says error and i cannot play any music. What else should i try doing?
If your GPX MW240S MP3 player is displaying an error message and not playing any music, there are a few things you can try to fix the issue:
  1. Reset the player: Sometimes resetting the MP3 player can fix the error. To reset the GPX MW240S, press and hold the power button for 10 seconds, release the button, and then turn the player back on.
  2. Check the music files: Ensure that the music files you are trying to play are in a compatible format with the GPX MW240S. The player supports MP3 and WMA formats, and if your files are in a different format, they will not play. You can convert the files using a free online converter.
  3. Update the firmware: If the player's firmware is outdated, it may cause errors while playing music. You can update the firmware by downloading the latest version from the GPX website and following the instructions.
  4. Check the storage space: If the MP3 player's memory is full, it may cause errors. Delete some files from the player to free up space.
If none of these solutions work, there may be a hardware issue with the player, and it may need to be repaired or replaced.
2/26/2023 2:26:50 PM • GPX Audio... • Answered on Feb 26, 2023
On my gpx cd home music system HM38170T the cd door won't open. How do I fix it?
If the CD door on your GPX CD home music system HM38170T won't open, here are a few steps you can take to troubleshoot the issue:
  1. Check for obstructions: Make sure there is nothing blocking the CD door or the area around it. Sometimes small objects or debris can get stuck and prevent the door from opening. If you see any obstructions, carefully remove them.
  2. Power cycle the system: Turn off the system and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. Sometimes power cycling can help reset the system and fix any issues.
2/19/2023 10:00:38 PM • GPX Audio... • Answered on Feb 19, 2023
2answers
Downloading songs from itunes to the MP3 player
The GPX mp3 player is incompatible with iTunes (as are most non-iPod mp3 players). There are a few mp3 players out there that are iTunes compatible, but this is not the one.
-Tha Mp3 Doctor
11/18/2022 3:15:32 AM • GPX Audio... • Answered on Nov 18, 2022
3answers
Where can i go for free music for my gpx mw151p 4gb
i wouldn't recommend doing so (piracy is a crime) but there are some free services out there to get music just becareful of what you download from the internet
3/12/2022 11:10:03 AM • GPX Audio... • Answered on Mar 12, 2022
Brand new GPX mp3 player will not pair or show up on usb drive
Instruct the computer to search for it. The computer should automatically find it and load drivers, but it should show in Windows Explorer as a volume in the left pane. Where are you looking? It will only pair with a computer if the computer has Bluetooth and most don't. Pair with a smartphone. How do I transfer my music to my device? This device is capable of playing MP3 and WMA (4ithout DRM) files. To load files requires a computer with a USB connection and the minimum requirements of Windows XP .
  • Connect the player to the USB cable provided in packaging, and then connect the other end to your computers USB port.
  • Once connection has been made between the device and your computer, a "GPX" drive will appear in the computer directory.
  • Double click on the GPX drive
  • Drag and drop your MP3 files and folders into the Music or playlist folder
https://gpx.com/on-the-go/gpx-bluetooth-mp3-player-mwb308r.html ..
3/6/2022 8:42:20 PM • GPX Audio... • Answered on Mar 06, 2022
My gpx mw3837 isnt turning on?
RETURN IT TO PLACE PURCHASED AS DEFECTIVE .
1/7/2022 1:56:14 AM • GPX Audio... • Answered on Jan 07, 2022
I need the manual for GPX Model KCCD3004DP
There isn't one for that particular model https://www.google.com/search?q=gpx+model+kccd3004dp+manual ..
11/19/2021 8:28:37 PM • GPX Audio... • Answered on Nov 19, 2021
NEED Instructions or Manual for GPX Model HTMU3234....
Contact GPX or its distributor to determine availability and source.
9/6/2021 4:30:41 AM • GPX Audio... • Answered on Sep 06, 2021
2answers
Every time i try to
Many online music stores employ DRM to restrict usage of music purchased and downloaded online. The best way to overcome this is to download DRM- free tracks. Some online music stores such as amazon, eMusic and Beatport give you DRM free tracks. Try getting your music from them. Or else you can rip the Cds to get the tracks.
hope this solves your problem.
FixYa!!
4/9/2020 9:31:14 AM • GPX Audio... • Answered on Apr 09, 2020
Gpx s7050 cd open/close button not working. is there a fix?
Sometimes there's a small pinhole in the face of the door panel. If so, straighten a paper clip and press straight into the hole. That will press lever that pushes the slide outward. If no pinhole, try a case knife (table knife). Shove between the door panel and the casing, and try to pry it panel outward. Once, not too long ago a friend lost a CD. They were sure they put it into the player on the laptop. When removing the CD player, I found the CD laying atop the player casing, so either they shoved it in the crease between the player and the laptop casing, or it popped up as they were closing the door ind it was shoved int hat crease. Good luck.
3/21/2020 8:06:20 PM • GPX Audio... • Answered on Mar 21, 2020
GPX HTD2204 System Logo
8 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
samsung av r720 front right speaker
  • Audio Players & Recorders
