20 Most Recent GPX MW-3847 MP3 Player Questions & Answers
the hold button on the side might be on. this happened to me while triying to add some files.
GPX MW-3847 MP3... | Answered on Dec 04, 2013
you might be able to or you can also buy the right charger for it.
GPX MW-3847 MP3... | Answered on Jul 11, 2013
mine is kinda backwards....i have to slide the thing to OFF for it to turn on....its weird...maybe that is the problem u r having?
GPX MW-3847 MP3... | Answered on Apr 27, 2011
just click on it and click delete if that dont work you probly have your mp3 on hold
GPX MW-3847 MP3... | Answered on Jan 27, 2011
here you go: open disk utility click on the sansa clip listing on the left- not the disk itself( the device) click the Partition tab under volume scheme, choose 1 partition click the options....button choose master boot record, the click ok (THIS IS IMPORTANT) click the drop down nest to format: and choose MS-DOS(FAT) click apply. when this is complete, you can eject the disk if needed, and your clip should be back to normal. this should be what you need, if not, click for more support, I will help (got a 4gb myself-christmas present). hope this helps, and please take a minute and rate the service
GPX MW-3847 MP3... | Answered on Jan 14, 2011
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
GPX MW-3847 MP3... | Answered on Jan 02, 2011
Use Windows Media Player to download music to your player.
To delete songs from your player follow the method below.
FREE answer, Please rate me
GPX MW-3847 MP3... | Answered on Dec 06, 2010
After connecting the MP3, search for all files int he drive using a file search. Use a (*) to search for all files and chose files only in the location of the MP3. All files will come up on the screen with which you can check and delete. I would ask you to remove all files to a folder , format the MP3 memory and reload all safe files.
GPX MW-3847 MP3... | Answered on Aug 30, 2010
With my Sansa Clip I just have to make sure it is set to MSC, then I can always see the files in the Clip from my computer. I transfer a lot of mp3 files to the Sansa Clip from a SmartCard with a Memorex TravelSync connected to both the Clip and a SmartCard reader. Initially, I couldn't figure out how I could play them on the Clip but not see them when connected to a computer. But when I set the USB Mode to MSC, I could see all the files.
GPX MW-3847 MP3... | Answered on Jul 24, 2010
unfortunitly i dun think it does but there are plently of adapter u can find at ur local elecltronic shops like best buy that should have maybe one thats simlar to ur needs
GPX MW-3847 MP3... | Answered on Apr 17, 2010
you shouldn't need a cd to install drivers. Windows XP and newer will automatically find and install the drivers. as far as organizing the songs, no, unless you can delete everything and start from the begining and sync just the music you want.
If you are using Windows Media Player to sync, it will put the songs on the player in the order you have them in the sync list.
If its just one song you like, there is a repeat one song option, push the middle button until it shows 'rep 1'.
GPX MW-3847 MP3... | Answered on Apr 04, 2010
You should be able to just plug in the usb cable and it will charge automatically, if your computer has the drivers installed for it. you may be able to test it with a Motorla wall charger to see if the battery will even take a charge.
GPX MW-3847 MP3 Player Logo
109 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
lost stuff
  • Audio Players & Recorders
