Refrigerators Logo
c
christel leitz Posted on Nov 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The display screen shows OF in both freezer and refrigerator h0w do i turn the freezer and refrigerator on?
Dakshinamurthy Nagarajan
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 89 Answers
  • Posted on Nov 27, 2017
Expert
Level 2:
Cheetah:
Night Owl:
Answers
89
Questions
0
Helped
22147
Points
201
Pl.check up the incoming power.Plugged properly.Check up MCB/ fuse control in power coming to Fridge/ also in the Fridge.
If you are unable to find out call eletrician to attend.
2answers
How do I turn demo mode off on my Lftr1835vf3
Press the "Freezer" and "Refrigerator" buttons on the control panel at the same time and hold them for 5 seconds.
The control panel will beep, and the temperature settings will be displayed. Keep holding the buttons until the control panel beeps again and the display goes blank.
After the display goes blank, release the buttons. Demo mode should now be turned off.
If the display still shows the word "demo" after following the above steps, try unplugging the refrigerator from the power outlet for a few minutes, then plug it back in and try the steps again.
If these steps do not work or you need further assistance, refer to your refrigerator's user manual or contact LG customer support for additional guidance.
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 • Freezers
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Frigidaire Gallery side by side error codes
SB is in "Sabbath Mode".
The Sabbath Mode is a feature that disables portions
of the refrigerator and its controls .
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "down" and refrigerator "up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode.
3helpful
Samsung RB215LASH freezer not cooling ice maker stopped working
Do you see any ice buildup on the back wall of the freezer?
LG LFX25980ST REFRIGERATOR W/BOTTOM FREEZER SHOWS MESSAGE ON DISPLAY ER IF WHAT DOES THIS MEAN
The control is not seeing a feedback signal from the ice room fan. (the fan inside the freezer which pushes cold air up to the in door icemaker) It is probably blocked with a build up of ice or frost, preventing the fan blade from turning.
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Freezer fault
I had this on my S20brsb they said it was "change filter", I did but it didnt go away. They came to look at it for a fee, fitted a new board alledgedly and charged me £200.00 it failed again after 13 months so Im back to square 1. Hope you have more luck, try the filter it might ork for you.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
