Zanussi ZHQ575 Electric Double Oven Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zanussi zuf270x main oven not getting hot
Hi, I have this oven, just out of warranty, and the main (bottom) oven for some reason isn't gettng hot. the light comes on, but not heat whatsoever.
Is this a relatively simple fix, and if so, which part should I be looking for?
Many thanks
Dylan.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2157
Points
19
I've just mended this myself and it took about 15 mins:-)
It's more than likely the heating element, you can get one off the internet for about £20 if you go for the electrolux replacement.
Open oven door and remove the trays, undo the four small screws on the back wall inside - not sure if you have to, but I turned the power off at this point. Better safe than not! Turn this around to the right wall as it won't come right out due to the bit of wire on the right (temp sensor maybe?).
If you've already got the new element you can guess what happens next; take out the 3 small screws holding in the element and gently pull towards you. It's attached to two wires poking out of two holes - take the bottom one off first as it seemed to have less tendency to fall back in the hole (I reckon that could be a real pain to get back).
Hold the wire still and wiggle the old element to remove as you will have less chance of damaging the wire that way. Reconnect the wires to the new element and pop it back together again.
Job done and after a year of waiting we now have double the oven space!
Barry Coates
Level 3:
  • Zanussi Master 3,463 Answers
  • Posted on Jul 29, 2009
Barry Coates
Zanussi Master
Level 3:
Answers
3463
Questions
Helped
1407048
Points
12766
If it is a fan assisted oven, and the fan is working o/k, then I would suspect that the oven element has failed, and will need to be replaced.
Please rate my solution.
Thanks.
1helpful
2answers
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
9helpful
2answers
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
2answers
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
1helpful
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
1helpful
2answers
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Thanks.
1helpful
Zanussi double oven ZDQ895 top of the oen is hot but oven will not come to temp bottom part of oven feels cool (fan oven)
If the fan is working o/k, then you need to fit a new oven element located behind rear cover of oven compartment.
Thanks.
My oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Thanks.
1helpful
2answers
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
