SOURCE: LE code on LG front loader
Switch off machine, unplug, turn the heat setting on the water down. Plug it back in and select your wash setting. Good luck.
SOURCE: LG WD(M)- 16220FD Error LE
The problem you are having is with the Hall sensor. To be 100% sure, here is the test proceedure, it is located on the stator. Replace this and your problems will go away. If you are not already using HE detergent, start using it, as well cut back on your fabric softener.
Sgt 48
SOURCE: WM0532HW LG front loader washing machine displays LE
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000.
SOURCE: LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG
was no help on the phone and I the only people that could service it
were 45min away from were I live. I took the advice of a posting on
this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next
unclip the two sets of wires on the bottom of the circle you are
looking at (the set of wires to the right are connected to the sensor
assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Have a LG front loader
For LG's 'LE' stands for 'Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
We cannot help any further from a distance.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
